  • October 31, 2020, 08:38:06 PM
Author Topic: Add led to fans?  (Read 2625 times)
shah
Add led to fans?
« on: August 16, 2003, 06:23:56 PM »
Is there a website or tips that tells you the best way to add LED's to your fan?
[D.o.S] LukeDG
    • http://www.csamovie.co.uk
Add led to fans?
« Reply #1 on: August 16, 2003, 06:25:53 PM »
www.google.com try searching
AXP 2400 @ 2236 (166x13.5) Cooled by SP-97
512MB PC2700 Generic Ram
ATi Radeon 9700 Pro @ 342/666
80GB Maxtor 2MB, 120GB Seagate 8MB, 80GB Maxtor SATA 8MB
shah
Add led to fans?
« Reply #2 on: August 16, 2003, 06:26:20 PM »
I did. All i got were LED fans
beautydies
    • http://www.atlantaaction.com/openyoureyes/
Add led to fans?
« Reply #3 on: August 17, 2003, 12:37:08 AM »
personally..id say hell with it and buy actual ones...that'd be too much of a pain in the ass to do it on your own.
snow veil
Add led to fans?
« Reply #4 on: August 17, 2003, 01:47:53 AM »
Well that sure takes the fun out of the whole process beautydies.
It's not too difficult to do so that you'd really need a guide...just drill holes for the LEDs, put them in with hot glue (making sure that the fan blades have clearance, of course), then wire them up.
Zero Nova
Add led to fans?
« Reply #5 on: August 17, 2003, 02:01:33 AM »
sometime you just have to put that uncontrollable urge to mod everything you see aside
and just take advantage of lifes premodded possessions. Only when one can achive this,
can you truely find nirvana in ones self
Chunks
Add led to fans?
« Reply #6 on: August 17, 2003, 02:18:04 AM »
Quote from: [D.o.S] LukeDG
thats the kind of answer that gets people beaten up.
LINK
shah
Add led to fans?
« Reply #7 on: August 17, 2003, 08:03:41 AM »
Thanks guys. My problems is that I can't find any 120mm Fans that have LEDs and yet have a great airflow.
shah
Add led to fans?
« Reply #8 on: August 17, 2003, 08:28:08 AM »
Do you guys think that a 5mm Led will work? I mean we are basically grinding the LED in half.
shah
Add led to fans?
« Reply #9 on: August 17, 2003, 08:58:02 AM »
also, does the Viewing Angle matter?
Page created in 0.071 seconds with 47 queries.
