  • June 06, 2020, 09:28:39 AM
Author Topic: Old monitor plug conversion  (Read 4230 times)
NEO-THE MATRIX
« on: August 15, 2003, 04:36:30 PM »
Ppl, remember those old monitors with the green blinking scoll thing?
I came across a new one and it is now in my hands but the connector is the sort of dual row of pins and not the normal vga plug.
Can anybody please guide me to a decent site or has knowledge how to rip the old connector into a vga one?
I know it would be better to get a new monitor by my ex physics teacher told me that I could easily convert one into a functional cro but she only knows how to do it with the normal vga connector.
thanks again
*Celeron D 2.6GHz oced 3.33GHz*
*2x Corsair PC 400 DDR RAM 256MB*
*ABIT IC-7G MOBO*
*GeForce 6600*Internal Sound Mixer*
*SoundBlaster Audigy*SoundBlaster Pro*
« Reply #1 on: August 15, 2003, 04:49:39 PM »
...i dont know much about it but wouldnt that be a SCART connector?
NEO-THE MATRIX
« Reply #2 on: August 15, 2003, 04:53:01 PM »
no, not the scart one, it looks like a sub D 9 pin plug, just slightly wider
*ABIT IC-7G MOBO*
Ykarts4u
« Reply #3 on: August 15, 2003, 07:43:51 PM »
is it an apple monitor style plug? that sounds like what you're describing
Rhinoceruses don't play games. They f*cking charge your ass!
mad_scientist
    • http://casemodz.org/mods/mike/mike.html
« Reply #4 on: August 15, 2003, 10:06:38 PM »
I belive your talking about a cga connector or a monochrome connector looks close to a vga or svga except it only has 2 rows of pins.
NEO-THE MATRIX
« Reply #5 on: August 16, 2003, 12:02:32 AM »
Exactly like mad scientist said, cause the monitor used to belong to an old 286 IBM compatible PC, the pc had a generic name so I cannot exactly tell you while the monitor had its sticker removed and replaced by the same brand of the pc - "GEM 286"
*ABIT IC-7G MOBO*
TemplaraPheonix
« Reply #6 on: August 16, 2003, 12:58:03 AM »
Um... here's the pin outs for 15 pin VGAs and 9 pin monitors.
http://www.monitorworld.com/faq_pages/q17_page.html
The only other thing is a 15 pin low density vga, which follows the vga pin out, but has the pins in two rows instead of three. You just need to bridge the pins. I'd invest in a VGA D sub and a compatible D sub and just connect the dots.
NEO-THE MATRIX
« Reply #7 on: August 16, 2003, 07:15:49 AM »
Wow thanks, that is wot I needed, I will start the conversion from 9 pin to 15 pin and from monitor to cro as soon as possible
*ABIT IC-7G MOBO*
Page created in 0.055 seconds with 33 queries.
