  • January 28, 2020, 09:59:05 PM
Author Topic: 120mm Fan noise killer homemade?  (Read 1771 times)
shah
« on: August 14, 2003, 06:27:34 PM »
Are there any ways to reduce the noise of a 120mm fan? I know Antec makes noise killer but I don't feel like buying it and paying 15 bucks for something that I could prob make.
Are there any mods that show you have to make one or something?
TokMor
« Reply #1 on: August 14, 2003, 06:29:12 PM »
well, you can reduce the noise by lowering the voltage going to it by putting a resistor on the power wires. or you could try putting rubber washers between the fan and the case.
shah
« Reply #2 on: August 14, 2003, 06:30:42 PM »
it is going to be mounted to a radiator. I think I will try the rubber washers.
Dr. Caligari
    • http://www.humboldthydroponics.com/
« Reply #3 on: August 14, 2003, 06:32:05 PM »
you can 7v it too, ground the black wire to the 5v line... uhm, black wire from fan to red(?) wire from PSU.
Also, rubber gromets, doesn't hurt performance, does kill a few dB.
edit: just saw the radiator comment, I've got my 120 grommetted to the case, don't need to do it to the radiator though.
shah
« Reply #4 on: August 14, 2003, 06:43:41 PM »
alright. Now do you guys know any 120m fan that have LED and above 90cfm?
Matt_T_Bratt
« Reply #5 on: August 14, 2003, 06:51:39 PM »
omg...don't ground 5v line...I don't think that's what he was trying to say...but... 7v you get from running the fan off the yellow and red wires, instead of the yellow and black, or red and black...
I think all the LED fans (120mm) were like, 60-70cfm that I've seen
Ykarts4u
« Reply #6 on: August 14, 2003, 07:05:56 PM »
he was saying put the ground line off of the fan to the 5v line, cause if you reverse it, you get 17 volts. :)
Rhinoceruses don't play games. They f*cking charge your ass!
zarbon7
« Reply #7 on: August 14, 2003, 07:44:14 PM »
i found a site, http:// http://www.allelectronics.com/ that has 120 mm fans with an output of 130 cfm @ 3500rpm. the only draw back is that its loud, 49 Dba loud. but 1 of those would be about the same as two fans.
zarbon7
« Reply #8 on: August 14, 2003, 07:45:38 PM »
oh yeah, they're only 5 bucks too. and i think thats just plain cool.
shah
« Reply #9 on: August 14, 2003, 07:54:08 PM »
49 Dba is loud but do you think the gasket will take some away like about 5 DBA?
Page created in 0.078 seconds with 32 queries.
