  • June 04, 2020, 02:14:58 AM
Author Topic: HELP! ps2 keyboard to USB using cat 5 cable  (Read 6007 times)
xgregrandomx
« on: August 12, 2003, 12:00:49 AM »
Would anyone be able to tell me how i could change a ps2 keyboard to usb? A small diagram would be nice :)  I wanted to have a secondary keyboard over by my bed so i can play games while laying down. I wanted to use some extra cat 5 cable to run it all the way over there and switch the plug to usb since i dont have an extra ps2 plug. Would this be possible? Thanx in advanced.
*waits patiently for LordZuul01*
« Reply #1 on: August 12, 2003, 12:05:51 AM »
You'd need some way to convert PS/2 to USB.  It's not a simple cable swap, I can tell you that much.  You'd probably have to get some hard core ICs and in the end, you'd probably be better off getting a whole new keyboard.  I mean, if you're up to the challenge, fine, but if you just want to use the keyboard from your bed, it's a lot more trouble than it's worth.
hermangarza
« Reply #2 on: August 12, 2003, 12:14:43 AM »
yeap just get a new keyboard or a converter or cable extender from a store that sells computer preheprials
soundman
« Reply #3 on: August 12, 2003, 12:16:02 AM »
what about one of those usb to ps/s converters. All those seem to be are peices of plastic could crack one of those open and find out.
« Reply #4 on: August 12, 2003, 12:36:04 AM »
Do they work backwards?  I had completely forgotten about them.
djpenguin
« Reply #5 on: August 12, 2003, 12:39:44 AM »
Changing USB to PS/2 is easy and inexpensive.  Changing PS/2 to USB is difficult, expensive, and rarely worth it.  For what you will spend on the converter, you could just buy a USB keyboard.
They just keep dancing
« Reply #6 on: August 12, 2003, 12:41:58 AM »
hermangarza
« Reply #7 on: August 12, 2003, 01:34:06 AM »
maybe this would be one of those thing that you should just buy a usb keyboard with ten feet?
daPyr0x
« Reply #8 on: August 12, 2003, 12:57:17 PM »
spend the 50 bucks on a cordless keyboard and leave it alone
:-p
Mobi
« Reply #9 on: August 12, 2003, 01:08:09 PM »
(c:
Wireless KB and Mouse maybe?
Page created in 0.402 seconds with 33 queries.
