  • July 09, 2020, 11:26:56 PM
Pages: [1] 2 3   Go Down
Author Topic: Where can I get 240v from in my case?  (Read 7493 times)
spikyhercules
« on: August 07, 2003, 07:18:56 PM »
This may sound daft but I have got my self eight 120mm x 120mm x 38mm 220/240v fans and was wondering if I could use them on my case the problem is they are 220/240v and a molex can only give me 5v, 7v, 12v & 17v I think so has anyone got an idea of how to power at least 1 of these beasts?
Psycho Clowns
« Reply #1 on: August 07, 2003, 07:25:49 PM »
They sound like they are AC fans rather than DC.
daPyr0x
« Reply #2 on: August 07, 2003, 07:26:01 PM »
220/240v??
what the hell do you have there??
are you sure they're DC fans?
minnick007
« Reply #3 on: August 07, 2003, 07:30:58 PM »
If they are AC fans you'll have to pull them from right in the power supply where the line comes in....I wouldn't reccomend it...Thats alot of juice
Ykarts4u
« Reply #4 on: August 07, 2003, 07:47:21 PM »
don't do it, the electromagnetic field those things throw off is nasty.
Rhinoceruses don't play games. They f*cking charge your ass!
spikyhercules
« Reply #5 on: August 07, 2003, 07:48:01 PM »
I'm not sure if they are AC or DC  all they say on the sticker is
220/240V~  50/60Hz
20/19W  0.12/0.11A
They are only 2900RPM but big & beefy  :D
daPyr0x
« Reply #6 on: August 07, 2003, 07:54:39 PM »
yeah, they're AC
cuz DC doesn't have a frequency (the Hz)
I'd hafta agree with Ykarts there...don't think it's worth it.
[edit] oh and btw, if you're in north america your entire computer doesn't run off of 220/240 volts....think about it dude...
Irateshadow
« Reply #7 on: August 07, 2003, 07:55:03 PM »
Those are AC fans. the 50/60 HZ is the oscillation on the lines that the fans use. You probabally shouldn't use them.
Edit: beat me to it.
LordZuul01
« Reply #8 on: August 07, 2003, 07:59:51 PM »
You will find that they are AC Fans for ppl outside the US... They will probably be universal motors... (IE they will run on either). The squiggle means that it expects AC... The fact that they accept 50/60 cycles probably makes them universal.
2 ways of getting your AC... You can wire an IEC socket to the fans, or you can run a set of cables from the back of the IEC socket inside the PSU. Make sure you use the ground lug on the fan, either connect it directly to ground, or ground it to your case. Most professional class servers only use AC fans. Look inside a compaq server...
As for electrical noise, they produce less electrical noise than a fan running on DC, and they move a fair bit more air. I use AC motors rather than DC motors when I need to cool large power supplies or MOSFETs in amplifiers.
:: LZ ::
I did an Ouch yesterday... tried to catch my soldering iron from falling off a ladder. (Pity seeking off)
modnut
« Reply #9 on: August 07, 2003, 08:17:20 PM »
holy crap those things are beasts.  i wouldn't risk installing them becaue of the magnetic field, it would really screw up stuff in your case.  what would you use those for?
Pages: [1] 2 3   Go Up
Page created in 0.084 seconds with 34 queries.
