  • July 05, 2020, 09:31:33 AM
Author Topic: wiring question  (Read 4984 times)
ReAX222
wiring question
« Reply #10 on: August 05, 2003, 07:39:14 PM »
If you are using USB, could you not just use the 5v from the usb and power a few leds?
All opinions, expressed or implied, are mine.  If you do not like it or disagree, get stuffed.
djpenguin
wiring question
« Reply #11 on: August 05, 2003, 08:40:02 PM »
You could.  Not a whole bunch, but a few would work out  fine.
They just keep dancing
hermangarza
wiring question
« Reply #12 on: August 05, 2003, 10:23:55 PM »
go to radio shack that where i go to get mod ideas
BuSkillS
wiring question
« Reply #13 on: August 05, 2003, 10:54:13 PM »
hmmm ye i would just run one long wire form the converter down the same wire as teh keyboard to your comp.
hermangarza
wiring question
« Reply #14 on: August 05, 2003, 11:18:47 PM »
and them some split looming or walmarts spiral looming
modnut
wiring question
« Reply #15 on: August 05, 2003, 11:35:11 PM »
Quote from: hermangarza
You could combine them with some really long heatshrink tubing.
hermangarza
wiring question
« Reply #16 on: August 05, 2003, 11:54:55 PM »
but it would not look even in some places of the cable
TemplaraPheonix
wiring question
« Reply #17 on: August 06, 2003, 12:14:44 AM »
Why not mod an old 8 wire LAN cable? 2 for power, and 6 for keyboard (allowing both PS/2 and USB styles). You can use a custom connector and drill a hole, or have two wires with stock connectors join somewhere behind your case. Just have the single cable go into your keyboard and reconnect the data lines.
hermangarza
wiring question
« Reply #18 on: August 06, 2003, 12:19:59 AM »
there would be problems there
donimages
wiring question
« Reply #19 on: August 19, 2003, 10:56:30 AM »
Exactly how many amps can be pulled from within the keyboard before running into problems?
Page created in 0.07 seconds with 46 queries.
