  • July 13, 2020, 12:20:50 AM
Pages: [1] 2 3   Go Down
Author Topic: wiring question  (Read 5036 times)
beautydies
    • http://www.atlantaaction.com/openyoureyes/
wiring question
« on: August 04, 2003, 12:04:04 AM »
okay i want to do a keyboard mod...
like this http://forums.bit-tech.net/showthread.php?s=&threadid=36192
but im not exactly 100% how to power it. can i just run a really long wires...say about 10-15ft long from the inverter, to a molex connector inside my case? the length of it wont effect it will it?
thanks in advance
wiring question
« Reply #1 on: August 04, 2003, 12:41:03 AM »
There will be some resistive loss, but it should work out.
hermangarza
wiring question
« Reply #2 on: August 04, 2003, 02:06:17 PM »
sound like a good mod idea
bleo8onhs
wiring question
« Reply #3 on: August 05, 2003, 09:09:59 AM »
It will work just fine...
hermangarza
wiring question
« Reply #4 on: August 05, 2003, 09:44:05 AM »
same connectors?
beautydies
wiring question
« Reply #5 on: August 05, 2003, 03:41:45 PM »
goodtimes..thanks..
now when i get some money..ill do it :)
damn car tag....*mumbles*
hermangarza
wiring question
« Reply #6 on: August 05, 2003, 03:46:56 PM »
not sure but myabe you can combine both wires
beautydies
wiring question
« Reply #7 on: August 05, 2003, 05:41:21 PM »
i was just thinking id tape the wire to it..
and now thinking about it..wow this would be a pain in the ass to take to lan parties..hmm mabe i can set up a molex connect at the back of my case....hmmm
hermangarza
wiring question
« Reply #8 on: August 05, 2003, 06:36:27 PM »
or a 4 pin connection like for the new motherboards i think radio shack still has them in stock
Geet Lord
wiring question
« Reply #9 on: August 05, 2003, 07:33:25 PM »
you could replace the cable like the guy did on the origonal one
that would be the best solution, though you could probably use a normal usb plug instead of one of his custom types
Pages: [1] 2 3   Go Up
Page created in 0.076 seconds with 34 queries.
