  • September 28, 2020, 10:41:12 PM
Author Topic: PDA Connectivity Issues  (Read 400 times)
Mr.Mysteriosity
« on: July 30, 2003, 08:22:52 PM »
I just finished a major upgrade of motherboard and CPU, which required me to repair my windows installation and reactivate windows.  Now I can't get my PDA (Handspring Visor Platinum) to synchronize with the computer. Every time I try to hotsync it detects the PDA as new hardware, looks for the driver, and doesn't find it, ending with a botched install. It worked before the upgrade, and windows found the driver automatically. Does anyone have an idea about the cause or the solution of this?
Thanks for all the help you provide.
EDIT: by the way, that's USB synchronization, and I did install new USB drivers with this upgrade.
Page created in 0.296 seconds with 33 queries.
