  • April 04, 2020, 09:34:06 AM
Author Topic: making boards  (Read 3726 times)
_Mantis_
    • http://www.lanparty.visiems.lt
making boards
« on: July 28, 2003, 03:52:51 PM »
Does anyone know how to make a pcb board at home or whatever you call thos things.
P.S. don't tell me for some special stuff beacause radioschacks in my counter are verry pour on variaty.
 :cry: thanx :D
making boards
« Reply #1 on: July 28, 2003, 03:54:19 PM »
Get a PCB without traces.
A pen and acid to make the traces, that's all.
Then a drill bit with a diameter below 1mm to make the holes.
making boards
« Reply #2 on: July 28, 2003, 03:55:26 PM »
your best bet on getting them from a local store is radioshack.  Ask for their "PCB Etching kit".  other than that, all you need is a copper-clad board, Etching solution (Ferric chloride [FeCl]) and a plastic tub, a sharpie, or masking tape and cutters.
zeno
making boards
« Reply #3 on: July 29, 2003, 02:08:48 AM »
You could use plastic board wrapped in tin foil, which should be glued to the board. draw the circuit on the paper, trace it to the foil, cut it with the exacto, poke holes than solder componets. Im not exactly sure if that will work, but that is the cheapest way. You should use copper-clad board if you want best results, also those "PCB kits" are very easy to work with:)
_Mantis_
« Reply #4 on: July 29, 2003, 03:59:28 AM »
hm... nice ideas first i would like to know what kind of acid do you use and if it's not a problem could you describe the whole procedure. :wtf:
Second what about those pcb kits, could you name some of them with brand name and model nr.  :tool:
Thnx :D
MindHacker
making boards
« Reply #5 on: July 29, 2003, 10:21:47 PM »
I like the foil idea.... wow.... I'm gonna try that, thanx.
256 9600pro,  <|>  none
80gig            <|>  Tera
_Mantis_
thanx
« Reply #6 on: July 30, 2003, 04:44:35 AM »
well thanx everybody...
ideas helped is some way... :thumbsup:
But last night i found a great link it realy helped me
http://www.veys.com/modules.php?op=modload&name=news&file=article&sid=7&mode=thread&order=0&thold=0
Page created in 0.071 seconds with 33 queries.
