  • April 04, 2020, 11:05:50 AM
Author Topic: Relay Pins  (Read 4080 times)
Zero Nova
Relay Pins
« on: July 28, 2003, 10:21:13 AM »
If i got a relay and the pins are marked "NO", "C", "NC"   what the heck does that mean, and which ones do i connect the power and the ground to.
Relay Pins
« Reply #1 on: July 28, 2003, 10:36:20 AM »
NO means Normally open
NC is Normally closed
C is the contact.
when the switch is off, C and NC are together.  when you turn it on, C will connect to NO.  So you would have two modes here, like if you want to toggle between two lines.  Now if you're just using this as a normal on/off switch, just use the C and the NO pins.
garlikbrd
  • i mod
Relay Pins
« Reply #2 on: July 28, 2003, 10:36:21 AM »
NO=Normally Open
NC=Normally Closed
  C=Closed ?
Depends on how u want to use the relay.
If u use the NO contacts, when the relay activates, the contacts will close and u'll turn on the things that u connect on the other side.
If u use the NC contacts. when the relay activates, the contacts will open and u'll turn off the things that u connect on the other side.
I had a sig once.
Japala
    • http://metku.net/
Relay Pins
« Reply #3 on: July 28, 2003, 10:41:15 AM »
Synchronized posting? ;)
Relay Pins
« Reply #4 on: July 28, 2003, 10:41:25 AM »
C = Common (it's common to NC and NO, both use it)
Japala
    • http://metku.net/
Relay Pins
« Reply #5 on: July 28, 2003, 10:42:58 AM »
You can use the Edit button...  :P
garlikbrd
  • i mod
Relay Pins
« Reply #6 on: July 28, 2003, 11:27:35 AM »
:lol:
I had a sig once.
Page created in 0.067 seconds with 33 queries.
