  • April 04, 2020, 09:31:54 AM
Author Topic: "Covering up" a cdrom window i dont like.  (Read 3424 times)
deejayry
    • http://members.lycos.co.uk/ryanparle
« on: July 16, 2003, 05:10:23 PM »
A few months ago i decided to cut a window in my cd rom and also one in the top of the case, but i have decided that i dont like the look of it.
Also i have a new cdrw/dvdrom combo, which i dont want to go cutting up.
I am now thinking of a way to cover up the cutting of the window.
I am fully open to sugestions.
So what do you think?
*edit* i will post some pics as soon as i get my digi cam back
TokMor
« Reply #1 on: July 16, 2003, 05:41:16 PM »
you could replace the window with smoked plexi so you can't see through it, and maby put a light behind it so that it still looks nice. Or etch the window with something colmpex so that it is not transparent.
F.U.C.T.
« Reply #2 on: July 16, 2003, 07:00:28 PM »
big ass sticker
« Reply #3 on: July 16, 2003, 07:02:35 PM »
You can just paint on the plexi if you want.
C3N7UR10N
« Reply #4 on: July 16, 2003, 07:10:39 PM »
sand it lightly for a frosted look. light comes out but no see in!
Anarchy Angel
« Reply #5 on: July 16, 2003, 07:13:05 PM »
Well you could but a fan and a fan grill there. Depends how big the hole is and how much room you got to work with.
StompFest : noun : A gathering of gamers that tread and/or trample heavily/violently on each other.
Stompfest!
triple_s
« Reply #6 on: July 16, 2003, 08:29:50 PM »
or you could completely rebuild the outter casing with something like aluminium or acrylic. Just an idea.
Havoc_108
« Reply #7 on: July 16, 2003, 11:58:36 PM »
uhh maybe a plain old fan? or uhhh lcd display? or um...... k i'm outta idea guess time to smoke a joint then.
castor jay
« Reply #8 on: July 17, 2003, 01:30:02 AM »
put the new cd drive on the top bay and the old one on bottom?? thats what id do cuz im lazy
deejayry
« Reply #9 on: July 17, 2003, 11:19:26 AM »
No room for lcd display, because my top bay will soon(ish) be home to a 4" tft screen fitted in the style of a car tv head unit, also described by X24 in a post on these forums.
I really dont like the idea of painting or frosting the plexi, because its the actual window i dont like the look of.
The only ideas i have so far are to cut the hole out a bit different, and fit either a shet of pollished ally, or a sheet of carbonfibre, i also will stealth my optical drive, and also the tft, when it is finished.
the stealthing will be done using the same matererial as what ever i use to blank the window
Page created in 0.06 seconds with 33 queries.
