  • July 06, 2020, 12:58:05 AM
Poll
Would You Buy A Diamond Heatsink If?
Total Members Voted: 18
Voting closed: July 03, 2003, 11:38:52 AM
Pages: 1 2 3 [4]   Go Down
Author Topic: How About A DIAMOND Heat Sink???  (Read 4990 times)
Psycho Clowns
« Reply #30 on: August 03, 2003, 07:35:52 PM »
Why not use crystal, I heard somewhere that the structure of a crystal was very similar to that of a diamond.  Sorry for the resurrection.
« Reply #31 on: August 04, 2003, 12:47:26 AM »
Diamond is a crystal.  Do you mean quartz?
cvngt
    • http://cvncpu.tk/
« Reply #32 on: August 04, 2003, 12:49:47 AM »
i think that all this dimond stuff is way to expensive but you guys do have a point about this cooling stuff...
Memfis
« Reply #33 on: August 04, 2003, 01:13:03 AM »
If i had the money id just get a VapoChill negative temps are good for me and no diamonds involved.
Psycho Clowns
« Reply #34 on: August 04, 2003, 08:52:39 PM »
Sorry about not being specific, Yes somthing like quartz.
DJ Bowen
« Reply #35 on: August 05, 2003, 02:57:15 AM »
Just imagine the bomb lighting mods with diamond heatsinks!
AzNPrideBoy
« Reply #36 on: August 05, 2003, 04:02:22 PM »
If it was a synthetic diamond, would it transfer heat the same way as a real one?  And there's no way to bring the cost down to around $50... the price of high end heatsinks.
bliq
« Reply #37 on: August 05, 2003, 04:18:32 PM »
even synthetic diamonds are expensive- not because of material costs but costs associated with making one- the 250ton press, the heat, etc.  Then having to carve one to the shape you want.  It maybe synthetic but it's still about as hard as a natural diamond- meaning you need another diamond to cut it.
C3N7UR10N
« Reply #38 on: August 07, 2003, 11:18:50 AM »
i like the idea of the micronized diamond thermal paste. i dont think itd be that expensive. ive bought diamond embedded saw blades for decest prices...
donimages
« Reply #39 on: August 19, 2003, 01:54:15 PM »
Typically, a hot device is soldered to a metallized diamond coupon. Diamond's exceptional thermal conductivity (500% greater than silver) allows heat to flow from the device into the bonded diamond heat spreader, which provides a lower thermal resistance pathway to the package's ultimate heat sink.
-from the website
Just a very thin layer of diamond between the die and HSF would do the trick as long as it's bonded to the die.
I'm thinking Pentium1 style package with diamond instead of ceramic. Make it thin and the cost would be reasonable (around $200 per CPU nowadays... in a few years possibly under $50?)
Would you pay a $50 premium for the diamond die? heh[/quote]
Pages: 1 2 3 [4]   Go Up
Page created in 0.123 seconds with 36 queries.
