  • July 09, 2020, 04:19:02 PM
Author Topic: 5.25 drive bay coolers  (Read 1621 times)
ozntz
« on: February 18, 2002, 01:17:00 PM »
I need two 5.25 drive bay coolers doesn't need to be for hd just for my inside airflow. If posable to match my silver Lian Li case.
brutal
    • http://www.brutal.tk
« Reply #1 on: February 18, 2002, 04:04:00 PM »
yea lian li makes some but they arent cheap: http://www.pcmods.com/details.asp?prodID=230  $69
_________________
P3 1gig w/Vantec CCK-6035 on Asus cusl2-c
Mushkin cas222 rev 3+ pc133 w/ heatshields
hercules gf2 gts 64meg
x-gamer 5.1 Live! with DTT2200 5.1 speakers
Win 98se build 2222 final
3dMark 2k1 3746
ozntz
« Reply #2 on: February 18, 2002, 06:36:00 PM »
thats not exectly what i was looking for i wanted something just with fans not a mobile hd rack
brutal
« Reply #3 on: February 18, 2002, 07:00:00 PM »
they are the onlythings that are a perfect match for lian li's
ozntz
« Reply #4 on: February 18, 2002, 09:43:00 PM »
ok know of anything that comes in white...
brutal
« Reply #5 on: February 18, 2002, 11:56:00 PM »
sure thats easy: http://www.coolerguys.com/cpucool/hdcooler.shtml
the ones at the bottom are tite
pewterpez
« Reply #6 on: February 23, 2002, 04:41:00 PM »
getting back to the lian li cooler / swapping thing
does anyone have one of those? a swappable hard drive? do they like it? when do they use it?
thanks
robert
rainman130
« Reply #7 on: February 25, 2002, 09:47:00 PM »
I bought my Bay Fan at CompUsa for only $10 i think. It has 3 fans in it. I dont put a HD behind it. It came in white but you can paint it i guess if you wanted to. Heres a link so you can see what i bought.
http://www.compusa.com/products/product_info.asp?product_code=50043546
brutal
« Reply #8 on: February 25, 2002, 09:49:00 PM »
pewter i had hot swap sca drives when i had my server here. they are cool, but i never really used them as they are intended for raid setups where you using hot backups and hot swaps
Page created in 0.472 seconds with 34 queries.
