  • June 02, 2020, 12:29:41 PM
Author Topic: Wiring this fan  (Read 1183 times)
neostar63
Wiring this fan
« Reply #10 on: June 02, 2003, 09:21:41 PM »
Yeah, I would most definitely test it first before i put it in with my most precious of cpu components. I wanted to see if it was possible. The 12 volt version is a little slower but it still pushes 235 Cfm's. Ohh it is tempting to try.
Wiring this fan
« Reply #11 on: June 02, 2003, 09:26:50 PM »
well then couldnt you connect one molex from one psu and another from another PSU?
but thats alot for one fan
Quagmire
Wiring this fan
« Reply #12 on: June 02, 2003, 09:33:00 PM »
just install a cheap secondary power supply just for a whole bunch of those fans
but jesus 300cfm??? thats awesome
Tachyon
Wiring this fan
« Reply #13 on: June 02, 2003, 09:44:12 PM »
But look at that big gaping dead zone! I mean really, the bulk of the part that's actually spinning is the motor. Don't they have an EM fan of similar size? Now that would be sweet. And then putting it onto the side of you case and ducting it straight to your heatsink.
Y'know, I think I'll replace my Prometia Mach II's stock fan with the 48V model! And pump it with Freon R-12 (licensed) like I did with my VapoChill.
Wiring this fan
« Reply #14 on: June 03, 2003, 02:52:02 AM »
Hey Tachyon, why haven't you ever posted pictures of your super-extreme -80C cooling system?  Even a MBM&WCPUID screenshot would be pretty awesome
Wiring this fan
« Reply #15 on: June 04, 2003, 02:45:46 AM »
There is no way (besides using the -12 volt rail) to get 24 volts from two 12 volt rails.  You'll have to get a dedicated 24 volt supply.
Amorphus
Wiring this fan
« Reply #16 on: June 04, 2003, 05:57:05 AM »
wiring it to two 12v lines in parallel to its positive line will still give you 12v.
wiring it 12v in series with the thing will give you a difference of 0v and the thing won't work.
however, you can run the 24v one at 12v and you're going to have a powerful, and quiet fan.
and the feathering at the end is reputed to reduce noise.  I'll pull up the link later.  something about vortexing.
Wiring this fan
« Reply #17 on: June 04, 2003, 11:38:45 AM »
That notching was/still is? used by the Navy on their subs to reduce the turbulence and therefore the noise of the propellers.
Page created in 0.07 seconds with 34 queries.
