  • June 07, 2020, 12:35:47 AM
Author Topic: Wiring this fan  (Read 1185 times)
neostar63
Wiring this fan
« on: June 02, 2003, 12:39:47 PM »
Is there a way to wire this fan up in your case using the power supply.
http://www.allelectronics.com/cgi-bin/category.cgi?category=220&item=CF-141&type=store
It moves alot of air, so its worth a try.
kickyourfaceoff
    • http://www.livejournal.com/userinfo.bml?user=johnnyfro
Wiring this fan
« Reply #1 on: June 02, 2003, 12:54:43 PM »
wire it to the 12V+ and 12V-  you should be alright
just make sure to put a grill on that, looks like it could take your finger off
Amorphus
Wiring this fan
« Reply #2 on: June 02, 2003, 01:30:21 PM »
NO!  DO NOT DO THAT!
ok, first of all, that draws 24v at 1A.  vantec tornadoes draw 12v at 1A.  and we all know that having more than 1 tornado in your system hurts.
also, since it draws 1A... you will OVERLOAD the -12v rail.  most of the time the -12v rail is only like 1A anyways, and your mobo uses most of that power.
bad, bad idea.  mucho bad idea.
kickyourfaceoff
Wiring this fan
« Reply #3 on: June 02, 2003, 02:11:03 PM »
oops my bad.
*smaks head on desk for not thinking.
Wiring this fan
« Reply #4 on: June 02, 2003, 02:18:55 PM »
You can get that fan in 12v, 24v, or 48v configuration.  Check it out.. .and fear those spikes on the fan blades... owch!
http://www.comairrotron.com/DCFans/PatriotDC.htm
Wiring this fan
« Reply #5 on: June 02, 2003, 02:50:13 PM »
wouldnt connecting it in series to the 12V of 2 molex connectors work?
ic0n
Wiring this fan
« Reply #6 on: June 02, 2003, 05:47:27 PM »
that could work.. possibly
best thing to do would be to get a test power supply, maybe 100W? you can probably get one at a swap meet or steal one out of your uncles 486
then test it on that
shouldnt mess anything up....
Nismo
Wiring this fan
« Reply #7 on: June 02, 2003, 06:46:52 PM »
whoa 235cfm thats lots of air :o
u should test it before installing it into your computer see if anything goes wrong
ic0n
Wiring this fan
« Reply #8 on: June 02, 2003, 06:48:08 PM »
yup :)
thats what i said
listen to us
ClearCaseMan
    • http://www.casemodman.com
Wiring this fan
« Reply #9 on: June 02, 2003, 06:50:51 PM »
Quote from: nemattoad
no it will not work the 12volt leads on the molex are all the same with the exception of having a diod seperating them
Page created in 0.287 seconds with 47 queries.
