  • January 18, 2021, 08:26:45 PM
Author Topic: Wiring Case fans  (Read 1451 times)
Dean
Wiring Case fans
« on: May 29, 2003, 10:52:55 AM »
i have just brought two Akasa AK-170BL4BSC Speed controlled fans. there are loads of wires coming out of the PSU, but none of them have connectors on the ends :wtf: . How do i wire my fans to it? :-?
Sorry for the newbie question :idiot:
Daneel
  • Briefcase PC
    • Clan | 43
Wiring Case fans
« Reply #1 on: May 29, 2003, 10:59:08 AM »
ok, if the connecters on the fans are 3 pin connecters then they plug onto the motherboard, otherwise you'll have to post a picture of the connecter.
if it is a 3 pin connecter and you don't have any spots on your motherboard, then you'll have to buy a 3 pin to molex adapter so you can power your fans off the PSU...
hope that helps.
Dean
Wiring Case fans
« Reply #2 on: May 29, 2003, 01:30:49 PM »
ok, the connectors on the fan are 3 pin connectors. I have connected it to the J16(System Fan) socket on my Gigabyte GA-7DX mobo. I powered up but the fan didn't work. :thumbsdown:
There is another socket j15(power Fan) which is a 3 pin socket. Should i try this and see if it works? :-?
HaloEight
Wiring Case fans
« Reply #3 on: May 29, 2003, 01:37:54 PM »
Buy a Sunbeam Rheobus v.2 and save yourself a headache.
Dean
Wiring Case fans
« Reply #4 on: May 29, 2003, 02:19:31 PM »
can anyone tell me how to connect my fan please :)
Wiring Case fans
« Reply #5 on: May 29, 2003, 04:03:53 PM »
Both the "System Fan" and the "Power Fan" are the same thing, just labeled differently.  Perhaps the fan is dead, or you have it plugged in backwards (although usually there is no way to plug a 3pin in wrong)  Its possible that your fan needs more power than the motherboard header can put out, so trying a 3pin to molex adapter may be the solution
Dean
Wiring Case fans
« Reply #6 on: May 29, 2003, 04:30:22 PM »
well the fan is brand new, so i hope it isn't dead :x
but thx for the suggestion i'll see if it works :)
Wiring Case fans
« Reply #7 on: May 29, 2003, 06:07:32 PM »
Dean
You may want to do this.
It's called Fanbus
You may search for it or ask if you want more info.
Dean
Wiring Case fans
« Reply #8 on: May 29, 2003, 06:11:18 PM »
hmm...looks interesting :thumbsup:
can you please tell me what it does, how much is it and can i get it from Maplins? :-?
sorry...i'm new to this modding stuff :idiot:
Wiring Case fans
« Reply #9 on: May 29, 2003, 08:40:33 PM »
That is a fanbus.  It basically lets you hook up bare wire ends to the 12 volt rail.  Not available through Maplins, but you can build one yourself without too much trouble.
Page created in 0.054 seconds with 33 queries.
