  • July 04, 2020, 01:22:42 PM
Author Topic: PSU Fan  (Read 4144 times)
Drakkon
    • http://dana.ucc.nau.edu/~cdd4/
PSU Fan
« on: August 13, 2001, 02:16:00 PM »
Is it possible to replace the power supply fan? Mine has gone out somewhat because it made a gradining noise then slower WAY down. it hardly blows a piece of paper away when put it in front of it :)
brutal
    • http://www.brutal.tk
PSU Fan
« Reply #1 on: August 13, 2001, 03:07:00 PM »
actually its very simple to replace the psu fan and i have on all of the my psus cause they are either weak or blow the wrong way.  just have some wire cutters and electrical tape or shrink tube around in case you have to cut the wires
Antacus
PSU Fan
« Reply #2 on: August 14, 2001, 10:17:00 AM »
Easy as pie like brutal said, if you got a standard psu. If not it can still be done, just a tad harder.
I had a friend that did not want to buy a new system (cost reasons) and his e-machine psu fan died. Took some works but I got a new one mounted.
brutal
PSU Fan
« Reply #3 on: August 14, 2001, 12:12:00 PM »
antacus, i always assume someone has a enlight or inwin or some other non generic case that the psu has 80mm fans and psu can be removed with 4 screws :)
Antacus
PSU Fan
« Reply #4 on: August 14, 2001, 12:24:00 PM »
yup yup yup. Was not ment to double guess ya there :)
Just stating, backhandedly, that if you go out the norm and buy a trash PC then fixing it is possible but not as easy. I hate e-machines :D
Justin Sampson
    • http://www.sampsonwebdesign.com
PSU Fan
« Reply #5 on: August 16, 2001, 01:42:00 PM »
I replaced one not to long ago and was super easy. The PS was 2 pecies and just pulled it appart, unplugged the fan and put a new one in. Actually I think we just sprayed the old one with WD-40 and put that back in. :D
Works fine now...
NMDante
  • Aaargh!
PSU Fan
« Reply #6 on: August 16, 2001, 10:17:00 PM »
It is simple.
I actually took it to another level.
I Dremeled out the bottom of my PSU to add another "sucking" 92mm fan on the bottom.  Then I added a high CFM 80mm in the back (92mm wouldn't fit, I tried... :(  )
I soldered both fans to the PCB (printed circuit board), and they work fine, and helped me drop 1-2 degrees just by adding the bottom "sucking" fan.
