  • September 28, 2020, 09:54:03 PM
Author Topic: Ausus ATN8X Revision 2  (Read 404 times)
Rolf
« on: May 24, 2003, 09:28:27 AM »
Nemattoad post- The Build your own pc parts list. Under the AMD ultra list, his choice for motherboard was the AUSUS ATN8X Revision 2. Revision 2, is this important and what does it mean. :roll:
Rolf
« Reply #1 on: May 24, 2003, 10:08:06 AM »
I might be butting more in to this then it is - Just a newer version!
ok321letsjam
  • Double Agent 1190 reporting for duty.
« Reply #2 on: May 24, 2003, 10:37:47 AM »
Did he mean the A7N8X?  That's the nForce2 board that runs stable with DDR400 memory (therefore, enabling you to use the 400MHz Barton processors).  The first nForce2 releases didn't always run well at 400MHz (200x2) FSB.  instead of releasing a whole new board, Asus just tweaked theirs a little and called it Version 2.
Intel Core 2 Duo E6300 (1.86 GHz) - Intel P965G Motherboard - 3072MB Adata DDR2-800 RAM -500GB Total Storage - nVidia GeForce 8600GTS 256MB - ATi Theater Pro 650 TV Tuner - And all I play is CouterStrike!
Nismo
« Reply #3 on: May 25, 2003, 12:23:05 AM »
i second that
Page created in 0.619 seconds with 34 queries.
