  • January 26, 2020, 01:42:09 PM
Author Topic: best AMD cooler  (Read 1522 times)
Helix
best AMD cooler
« on: April 20, 2003, 08:01:36 PM »
what do you think is the best heatsink for a socket A. i'm going to be overclocking my XP 2400 quite a bit so i need some serious cooling.
best AMD cooler
« Reply #1 on: April 20, 2003, 08:09:28 PM »
thermalright SLK-900 or the swiftech MCX462
fuSER
    • http://webpages.charter.net/aznfuser
best AMD cooler
« Reply #2 on: April 20, 2003, 08:15:54 PM »
i agree...but if you're going budget, get a gc69 or 88
best AMD cooler
« Reply #3 on: April 20, 2003, 08:17:15 PM »
Quote from: fuSER
he didnt say he was going budget, and what even is a GC69 or 88
best AMD cooler
« Reply #4 on: April 20, 2003, 08:18:00 PM »
actually now that i think about it...the thermaltake subzero4g
Excelsis
    • http://members.rogers.com/excelsis
best AMD cooler
« Reply #5 on: April 20, 2003, 09:26:31 PM »
If your not working on a budget you might want to consider water cooling.  If you are into serious oc'ing.
Behemoth69
best AMD cooler
« Reply #6 on: April 30, 2003, 09:30:09 PM »
i got the 2400 xp too. I was thinking of getting the vantec aeroflow. I will overclock eventually, but probally not all that much (maybe around 300-500 mhz). Right now i have a stock fan. Should i bother upgrading, or just stick with the stock?
DarkBacon
best AMD cooler
« Reply #7 on: May 01, 2003, 12:22:26 AM »
Prometia phase change cooler... but seriously either the SLK-800 (or 900 if you can fit it on your motherboard) or the Swiftec MCX462.
Storm_Crow
best AMD cooler
« Reply #8 on: May 01, 2003, 12:57:34 AM »
ive got a 2800+ and i use the Volcano 11
it keeps the CPU cool after an 800mhz oc (38C idle, 45C load)
if you get this be sure to lap the base - it reduced my cpu temps 5C!
Rock crushes scisors, but paper covers rock, and scisors cuts paper... we have a canundrum
best AMD cooler
« Reply #9 on: May 01, 2003, 01:53:07 AM »
Quote from: nemattoad
Thats the peltier jobbie?  I dont trust that very much, especially as its aircooled (if im thinking of the right one)
I second the SLK800/900 and swiftech MCX4000
If you want to go extreme, there is always water.. but its a lot more expensive
Page created in 0.079 seconds with 61 queries.
