  • July 11, 2020, 05:15:07 AM
Author Topic: AMD Athlon 1.2  (Read 5438 times)
CoDe_MaStEr_JoN
AMD Athlon 1.2
« on: August 12, 2001, 07:34:00 AM »
anyone know or know any web pages that could help me with overclocking my amd athlon 1.2??
thx
AMD Athlon 1.2
« Reply #1 on: August 12, 2001, 03:52:00 PM »
forumoc.com  not really a webpage but they pretty much all run amds they could help you.
CoDe_MaStEr_JoN
AMD Athlon 1.2
« Reply #2 on: August 13, 2001, 04:21:00 AM »
thx
CoDe_MaStEr_JoN
AMD Athlon 1.2
« Reply #3 on: August 13, 2001, 04:27:00 AM »
hmmmmmmmmmmmmmmm
site doesnt really have any guides
mostly just news
but thanks anywayz
AMD Athlon 1.2
« Reply #4 on: August 13, 2001, 06:39:00 AM »
well its a forum, and all they do are amds, they could get you on your feet if ask for help.
CoDe_MaStEr_JoN
AMD Athlon 1.2
« Reply #5 on: August 14, 2001, 03:52:00 AM »
i found that i can do some soldering on the chip and connect the L1 bridge, but
i am not really good at doing that and i dont want to take the risk of messing up,
are there any programs that can help me over clock the athlon
also if i just increase the clock multiplier in the setup will that overclock it??
thx
AMD Athlon 1.2
« Reply #6 on: August 14, 2001, 03:39:00 PM »
yeah have to unlock your chip first, if its locked... try cahning your cpu multiplier and see if it effects cpu speed, if so your chip is unlocked.
Justin Sampson
    • http://www.sampsonwebdesign.com
AMD Athlon 1.2
« Reply #7 on: August 16, 2001, 11:37:00 AM »
Hmm, I didn't think that 1.2's and up were locked? Are they?
CoDe_MaStEr_JoN
AMD Athlon 1.2
« Reply #8 on: August 17, 2001, 01:27:00 AM »
all i have to do is increase the mutlipler and that will over clock my comp???
also i heard i could increase my fsb. if that is true how would i do that?
CoDe_MaStEr_JoN
AMD Athlon 1.2
« Reply #9 on: August 17, 2001, 04:43:00 AM »
i can only increase my multiplier from 12 to 12.5
should i also increase my fsb
Page created in 0.163 seconds with 33 queries.
