  • February 21, 2020, 11:00:32 AM
Author Topic: sound dampening  (Read 566 times)
xstevex
sound dampening
« on: April 16, 2003, 02:38:22 PM »
my case is pretty darn loud right now with 3 92's in there but where's the most effective place to add some foam for sound dampening?the floor is an obvious one but anywhere else?
cutting away more from the hole for my top intake fan will do a lot from the air not whizzing past all the plastic anymore but i do have some extra foam laying around...
kickyourfaceoff
    • http://www.livejournal.com/userinfo.bml?user=johnnyfro
sound dampening
« Reply #1 on: April 16, 2003, 04:04:17 PM »
www.overclockers.com had an artical on using carpet to cut down on the sounds.   the guy made a wooden enclosure for his case and covered the inside and out side with carpet.  i dont see any reason why foam wouldnt help on the inside.
Ykarts4u
sound dampening
« Reply #2 on: April 16, 2003, 06:44:55 PM »
at Lowes in the roofing section is some stuff called Peel'n'Seal. It comes in a 6"x25' roll for like $13-14. It's pretty good. I use it in all of my own stuff.
Rhinoceruses don't play games. They f*cking charge your ass!
Page created in 0.07 seconds with 34 queries.
