  • June 06, 2020, 12:35:05 AM
Pages: 1 2 [3] 4 5   Go Down
Author Topic: 1100 CFM!!!!!!  (Read 3819 times)
qscwdvefzrax
question
« Reply #20 on: April 15, 2003, 01:09:07 AM »
Does anyone know at what cfm components (like capacitors) will start to be blown off the circuit-boards in the case?
Squeak
1100 CFM!!!!!!
« Reply #21 on: April 15, 2003, 01:46:56 AM »
i disagree with the matrix
hearing damage is caused by the hairs in the cochlea(i think) vibrating too much to the extent that they break off and then they dont vibrate and tell ur brain what you are hearing.
kickyourfaceoff
    • http://www.livejournal.com/userinfo.bml?user=johnnyfro
Re: question
« Reply #22 on: April 15, 2003, 09:18:48 AM »
Quote from: qscwdvefzrax
way more CFM than yoou need
1100 CFM!!!!!!
« Reply #23 on: April 15, 2003, 09:29:34 AM »
Well, its not so much caps and stuff I would worry about being blown off.  I would worry more about things like RAM and expantion cards.  But if your anywhere near the kind of CFM that you would be worried about that, you have way too big of a fan.  With that kind of CFM you create a lot more problems than you solve.  Basically the more air you move over something the closer to ambient temp you can get it, right up to a point.  After that, vertical sheer litterally creates a blanket of trapped air on the surface, with will actually heat up components.  And it takes suprisingly little force to do that.
Guycaico
1100 CFM!!!!!!
« Reply #24 on: April 15, 2003, 09:58:33 AM »
I am sorry but putting a fan like that in your PC is pointless. you should use that thing for a "food processor" or a juicer or even a blender. If you're creative you can throw suff in it and make it splatter on a canvas and be able to sell it for millions!!!  :D  :D  :D
DSLaBuda
    • http://www.modasylum.com
1100 CFM!!!!!!
« Reply #25 on: April 15, 2003, 10:02:53 AM »
Quote from: Guycaico
exactly, what happens when it sucks your ccfl off the bottom of your case and shreds it?  even worse, your cat is walking by and a little too close to the intake....i'll not go into detail about that one..
Guycaico
1100 CFM!!!!!!
« Reply #26 on: April 15, 2003, 10:09:09 AM »
Quote from: DSLaBuda
 :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:
That could get a trifle messy.... have fun cleaning that up....  :wtf:
saint-oni
1100 CFM!!!!!!
« Reply #27 on: April 15, 2003, 10:09:26 AM »
get 2 of them. set them side by side. build a housing for the both of them. have 1 blow in the front, and 1 suck out the back. cool your computer, and your house. just hafta go EXTRA heavy on the fan grills/grates/steel rebar. :lol: but for real, the only thing id ever use that for is if i REALLY wanted to piss off my neighbors. think "blowgun/potato cannon".
Guycaico
1100 CFM!!!!!!
« Reply #28 on: April 15, 2003, 10:12:04 AM »
Quote from: saint-oni
Hmmm..... Sounds like a good time for everyone, now how much were those fans again.....  ;)
DSLaBuda
1100 CFM!!!!!!
« Reply #29 on: April 15, 2003, 11:03:41 AM »
or put two on the bottom and one on the back and make a hover case.  just ride that puppy to lan's :D
Pages: 1 2 [3] 4 5   Go Up
Page created in 0.108 seconds with 104 queries.
