  • June 01, 2020, 08:24:32 AM
Pages: 1 ... 5 6 [7]   Go Down
Author Topic: Guide: Heatsink Lapping  (Read 15705 times)
insulglass
« Reply #60 on: August 07, 2003, 05:19:11 AM »
TONS?  Maybe we should do some business!   :D
chase!
  • The Internet!
« Reply #61 on: August 07, 2003, 07:13:31 AM »
Do you think this kit could be used for other things? Maybe something like this - http://www.mini-itx.com/projects/bantampc/ ? Or would you need a lot more sand paper for something like that.
insulglass
« Reply #62 on: August 07, 2003, 08:37:06 PM »
The contents of my kit would be perfectly appropriate for such a project.  However, you would not need to go nearly as high on grit level.  I think the higher grits in this application would be pure overkill and the elbow grease involved would not be fun to be a part of.
Also, you wouldn't need a "glass" kit but I would suggest two plain kits.
If anyone was truly interested, I would be glad to substitute and swap out some of the 1200/1500/200 grit sandpaper for extra 400/600/800/1000 as you desired.  Basically, I'd just work up a special bulk kit and provide a one-time or individual pricing.
Dave
insulglass@easypckits.com
insulglass
« Reply #63 on: September 01, 2003, 01:13:47 PM »
New premium kit coming out next week...here's a bit of eye candy.  Yes, the sandpaper really IS that color!  The new kit will be packaged with the standard stuff plus a tube of Arctic Silver Ceramique to use as the final lapping compound.  The black silicon carbide sheet is included int he picture for reference only.
If anyone is interested, I can explain why it is better.
Dave
www.easypckits.com
« Reply #64 on: September 01, 2003, 04:19:08 PM »
I can tell you why its better - its pretty!  Also, it appears that it would be easier to figure out what order to do things in, since you can easily tell which colors are which.
I like the new colors, keep up the good work!
insulglass
« Reply #65 on: September 24, 2003, 07:58:11 PM »
Thanks for the encouragement!   I have finalized the kit contents and started selling them.  Here's a pic...
http://www.easypckits.com/images/007.jpg
Dave[/url]
shah
« Reply #66 on: January 02, 2004, 10:59:03 PM »
I have been lapping for a while on 2 blocks. the first one as soon as I hit 2000, every thing become foggy and I have to go back to 1500 for the shine.
Another thing is that I can't seem to get the center on one of my blocks. Any tips?
AzNPrideBoy
« Reply #67 on: January 02, 2004, 11:13:55 PM »
Quote from: shah
If you can't hit the center, it means your edges are still raised higher than the middle.  Therefore, you must go back to a lower grit and sand it down until the edges are lowered.  Don't go on to a higher grit until the middle can be sanded.  Once you hit the middle w/ a certain grit, move on to the next grit.
Pages: 1 ... 5 6 [7]   Go Up
Page created in 0.064 seconds with 46 queries.
