  • July 12, 2020, 07:01:52 AM
Pages: 1 2 [3] 4   Go Down
Author Topic: high cpu temp  (Read 8093 times)
high cpu temp
« Reply #20 on: August 30, 2001, 01:36:00 PM »
erm... the cpu wouldn't survive at 100+ C...  the chip would of killed itself...
DougthaThug
high cpu temp
« Reply #21 on: August 30, 2001, 03:04:00 PM »
Maybe you could try artic silver epoxying a little copper ramsink on the back of your mobo where the cpu is. Just be sure not to touch any leads.  Also maybe put a bigger chipset cooler on your northbridge/southbridge.  Or just stick a big Ol' blower on the side of your case check out
"Good Air / Bad Air, Good Fans / Bad Fans, Good Grief!"
article in case cooling tips in overclockers.com
jargon
high cpu temp
« Reply #22 on: August 30, 2001, 07:06:00 PM »
i have as2 on the core already.  i have reseated heat sinc. maybe i should do the blow hole.
brutal
    • http://www.brutal.tk
high cpu temp
« Reply #23 on: August 30, 2001, 09:33:00 PM »
100 celsius is 212 farenheit, thats the temp water boils at sea level
high cpu temp
« Reply #24 on: August 30, 2001, 10:05:00 PM »
yes I know thats why it would of been dead...
otaconx
    • http://otaconx.net
high cpu temp
« Reply #25 on: August 31, 2001, 12:06:00 AM »
maybe he meant 100 farenheit, which isn't too much (well, it is, but it's nowhere near 100c)
but like i said, if it was 100c, it'd be more than ready to be put into a bag of lay's ;)
DougthaThug
high cpu temp
« Reply #26 on: August 31, 2001, 05:52:00 PM »
Oh i get it a fried chip! haha
Parez
high cpu temp
« Reply #27 on: August 31, 2001, 07:36:00 PM »
No i meant 100 C but we never took time to feel the actuall heat on the HSF, maybe the BIOS readings was wrong or something. That was also the first time he booted up his new comp, so we run it maybe 1 minute whit that fan on.
high cpu temp
« Reply #28 on: August 31, 2001, 07:40:00 PM »
amd says that thier chips will die if it reaches 90 C
Parez
high cpu temp
« Reply #29 on: August 31, 2001, 07:46:00 PM »
A reading error then...   'cos its still working fine. however i will still not recommend the super orb on a 1.4 T bird
Pages: 1 2 [3] 4   Go Up
Page created in 0.122 seconds with 41 queries.
