  • June 20, 2019, 12:09:02 PM
Author Topic: | AT PSU? Do they need the fans? |  (Read 1384 times)
Ronin
  • GURNING ALL WAY HOME.
« on: April 02, 2003, 07:52:01 AM »
Hi there I have a Old AT power supply and I was going to use it to power the CCFL\NEON\ K\b Lights for my pc but it will be out side under desk but the FAN is making a hell of alot of noise. But there is no hot air comming from it.
So Do they realy need the fans?
If so why?
I will replace the fan if I have to but I was just wondering......
Cheers
.-=Ronin=-.
Iv3 b33n H4x0r5.
isisfreak
    • Kickass Mods
« Reply #1 on: April 02, 2003, 07:56:40 AM »
If your gonna take the fans out I would just put it in a open area and make the vents on the cover bigger. But it would probably be better to replace the fan.
sonique
« Reply #2 on: April 02, 2003, 08:02:43 AM »
Not to sure, I would think that you should keep some airflow in there, as it might cook.
When we made our 36v peak-to-peak PSU's in my first year, those transistors got mighty hot, and they weren't very 'powerful' PSU's.
PMV
« Reply #3 on: April 02, 2003, 09:35:25 AM »
yes, you do need a fan in an AT PSU. My old 166 has a 300watt AT PSU in it, when the fan seized, the temps often went to 70-80*C and the case itself started to heat. Replaced the fan, hear no noise and PSU kept rather cool.
Replace the fan with a new one, all should be well :)
"I nine an eleven-eloin with my five'k"
« Reply #4 on: April 02, 2003, 09:48:42 AM »
Yes all powersupplies, regardless of form factor, need a fan.
Ronin
« Reply #5 on: April 02, 2003, 10:01:06 AM »
Ok Cheers for all your help.
Are the fanss a generic sizr or are they all different?
.-=Ronin=-. out.
Iv3 b33n H4x0r5.
PMV
« Reply #6 on: April 02, 2003, 10:06:44 AM »
most of em are 80mm...but measure to be sure.
simsicle
« Reply #7 on: April 02, 2003, 10:25:06 PM »
Quote from: merlinicorpus
Some desktop computers at college don't have any fans except the one on the CPU heatsink. Not even in the PSU. Sure has to be hot in there.
Ronin
« Reply #8 on: April 03, 2003, 02:58:05 AM »
Humm.
Well thanks for all your help.
I put in a Silent fan I had and its not the FAN its the PSU its making noises!
Is that ok?
I allways thought it was the fan that made the noise.
Please help me with this?
Is the psu alone supose to make a noise?
Iv3 b33n H4x0r5.
kickyourfaceoff
    • http://www.livejournal.com/userinfo.bml?user=johnnyfro
« Reply #9 on: April 03, 2003, 09:19:45 AM »
when one of my AT PSUs was going it would make a weird buzzing noise.
Page created in 0.058 seconds with 19 queries.
