  • November 23, 2020, 11:55:36 AM
Pages: 1 2 3 [4]   Go Down
Author Topic: Laser pointer fun  (Read 2458 times)
SteveyG
Laser pointer fun
« Reply #30 on: March 31, 2003, 05:48:02 PM »
Quote from: MaxamusCrasious
asctuall not all fog machines use dry ice some use fog juice (can't tell you exactly what is, but it is its name) to make the fog
In most commercial fog machines, triethylene glycol mixed with water is usually used.
broctannn
Laser pointer fun
« Reply #31 on: March 31, 2003, 08:44:08 PM »
still won't work the exaust fans will blow the stuff out
sonique
Laser pointer fun
« Reply #32 on: April 01, 2003, 07:58:35 AM »
They made 'laser art' at the Science Centre in the city..
They turned them all on and made a 'mirrorbox' with mirrors at the exact angles, which reflected all the beams onto the black wall into different shapes and stuff.. Looked pretty cool, but lots of laser pointers are needed. Just dont aim them at your eyes  :o
MindHacker
Laser pointer fun
« Reply #33 on: April 02, 2003, 12:53:29 PM »
The best way to do it would be to make a glowpad/window out of plexi with a bit of dust/imperfections made IN the plexi.  These would make the path show up. Then add mirrors at the edges and you get shapes.
256 9600pro,  <|>  none
80gig            <|>  Tera
Im_gumby
Laser pointer fun
« Reply #34 on: April 02, 2003, 01:09:54 PM »
PMV wrote:
if Im not mistaken. Firing a white light into a prism makes a multitude of colors. I wonder what a laser would look like in a prism?
nemattoad wrote:
the laser light is unaffected
Prism breaks up white light into it's component wavelengths.
Laser only has one wavelenth, it is only one color, therefore should be unaffected.
K101
Laser pointer fun
« Reply #35 on: April 07, 2003, 09:25:27 PM »
To get the lazer to show up,  sandpaper the plexy lightly with some high grit paper.  Wouldnt it still allow vision, but make the lazer more visable?
Pages: 1 2 3 [4]   Go Up
Page created in 0.065 seconds with 47 queries.
