  • November 23, 2020, 11:36:12 AM
Pages: 1 2 [3] 4   Go Down
Author Topic: Laser pointer fun  (Read 2456 times)
Laser pointer fun
« Reply #20 on: March 28, 2003, 07:26:03 PM »
Quote from: chrommonky
wouldn't you need to make the laser able to be seen? i thought all you could see from a laser pointer was the point...
yes, there are laser pointers that only show a dot, but there are some that have a beam also. like the green laser pointer on www.thinkgeek.com
the ones that show a beam tend to be more expensive and much stronger
suprastar
    • http://www.projectsuprastar.tk
Laser pointer fun
« Reply #21 on: March 30, 2003, 06:20:41 PM »
wow! you just gave me an awesome idea. there has to be some way to show the actual path of the laser if you shine it through the edges of plexiglass. if so, you could make such an awesome design by using mirrors to reflect the beam of light. you would have to angle the mirrors just right but i'm sure it could work.
PMV
Laser pointer fun
« Reply #22 on: March 30, 2003, 09:07:47 PM »
if Im not mistaken. Firing a white light into a prism makes a multitude of colors. I wonder what a laser would look like in a prism?
"I nine an eleven-eloin with my five'k"
Laser pointer fun
« Reply #23 on: March 30, 2003, 09:10:30 PM »
Quote from: PMV
the laser light is unaffected
broctannn
Laser pointer fun
« Reply #24 on: March 30, 2003, 09:19:04 PM »
you test that??
Laser pointer fun
« Reply #25 on: March 30, 2003, 10:10:09 PM »
no but if u want me to i will
Daneel
  • Briefcase PC
    • Clan | 43
Laser pointer fun
« Reply #26 on: March 30, 2003, 10:21:14 PM »
Quote from: broctannn
if you're shining it acctually through plexi glass you should be able to see it shouldn't you?  hm... smoking computer good :-?  :-? that's a change
 :lol: lol thats the first time i've ever seen anyone use the colour feature.
anyway, nematoad is right, laser light is unaffected because it is all in the one part of the spectrum anyway (ie red or green) so it doesn't rainbowise (forgot the word :P ).
also, most fog machines do it with dry ice, so running it through a computer is possible, although your fans would have a slightly heavier drag load on them...  i',m pretty sure that dry ice dosen't conduct so you're safe there...  please correct me if i'm wrong on th econduction bit
    • The Site Of Doom
Laser pointer fun
« Reply #27 on: March 31, 2003, 06:04:54 AM »
asctuall not all fog machines use dry ice some use fog juice (can't tell you exactly what is, but it is its name) to make the fog
beautydies
    • http://www.atlantaaction.com/openyoureyes/
Laser pointer fun
« Reply #28 on: March 31, 2003, 07:41:52 AM »
yeah....but then like you know, seeing all of us on average have 4 fans....
that stuff would just blow right out. so. any other ideas?
broctannn
Laser pointer fun
« Reply #29 on: March 31, 2003, 02:54:00 PM »
i'm gunna go buy some lazer pointers tomorrow and start experimenting, i'll try to pick up some mirrors too i like that design with a laser idea
Pages: 1 2 [3] 4   Go Up
Page created in 0.098 seconds with 75 queries.
