  • July 04, 2020, 04:32:38 PM
Author Topic: 2100XP Cooling Sugestions  (Read 2066 times)
deejayry
    • http://members.lycos.co.uk/ryanparle
« Reply #10 on: March 19, 2003, 01:28:43 PM »
Quote from: D.O.A
I am looking into both suggestions but I am leaning towards the coolermaster I just think it looks cool with those pipes.
thanks for the suggestions I will let you know when the decision is made
thats why i went for mine tbh, to start i was p115ed right off with it, it was hotter than my stock cooler, temps went up 10C then i fitted a bigger fan,but it made very little difference. that was on my 1600+palamino.
when i pulled it off of the 1600+ i noticed the base was badly scratched, so i lapped it in with 800grit wet&dry, which gave a better than standard finish. now when fitted to the 2100+TBred i cant get it past 37c. i'm using the silicone paste which came with the cooler, will try some silver stuff soon.
timid1
« Reply #11 on: March 19, 2003, 01:59:48 PM »
Quote from: D.O.A
I was thinking about the Volcano 9 but heard something about it being too heavy
I have the Volcano 9 on my XP 2100+ and it is working just fine.  Has provided me with EXCELLENT cooling.  Running 112 degrees F loaded, 104 degrees idle.  w00t!  :tool:
D.O.A
« Reply #12 on: March 19, 2003, 06:37:48 PM »
Well I went ahead and got the volcano 9 with the coolmod and then said what the hell and got the thermaltake duct mod  :D I will let you guys know how it works out and thanks for the help I looked at all suggestions and just found the Volcano for 20 bux so I said what the hell
isisfreak
    • Kickass Mods
« Reply #13 on: March 19, 2003, 06:42:30 PM »
What do ypu guys think is better Price/Performance wise the SLK-800U or the SLK-900U?
MadRh3toric
« Reply #14 on: March 23, 2003, 12:11:12 AM »
i know i'm late, but the SK7 gets my vote, 10 dolla cheaper than slk800, and with a low (34 cfm) cfm fan, i stay at around 27-30 deg. celcius
fuware
« Reply #15 on: March 23, 2003, 09:14:58 AM »
volcano 7+ works well for me.  Just make sure your case is moving air out from around the cpu.  I use a dual fan setup in the back to pull as much heat from around the cpu as I can.
Sock
« Reply #16 on: March 27, 2003, 05:57:32 PM »
Well, what about a cooler for an AMD XP 2100+, but on an Asus A7M266-D.
I lack the space to fit any huge coolers, so I need a different solution than that.
My dual AMD's only get to about 44 degrees on idle (25cfm HSF)
And go up to about 50degrees under use..
I need something else..
smokin_pc
« Reply #17 on: March 27, 2003, 10:41:44 PM »
well, i use a Tt volcano 7+ . i chose this cause it has the copper heatsink, and the fan is fast a quiet
TheM@trix
« Reply #18 on: March 27, 2003, 10:47:16 PM »
Vapochill
MadRh3toric
« Reply #19 on: March 30, 2003, 09:16:36 PM »
lollerskates!
i want a vapochill.... mmmmm vapochilly.
Page created in 0.089 seconds with 61 queries.
