  • July 06, 2020, 06:00:14 AM
Author Topic: Question about modding psu  (Read 1455 times)
*STFU*PhirstAide
    • http://www.teamstfu.com
« on: March 15, 2003, 12:47:37 AM »
ok, so i did what the guide said and i connected the green wire with a ground. then i hooked up a fan connected to a molex and voila, it works. now my question is this: do i always have to have something plugged into the molex when i power this up?
RentonLovesJunks
« Reply #1 on: March 15, 2003, 12:51:11 AM »
if its not connected with a motherboard, yes. i would reccomend putting a momentary on/ always off switch between the 2 so you could start it up easier.
if you plan on attaching to a motherboard, no mods nessary.
outther
« Reply #2 on: March 15, 2003, 01:30:26 AM »
It is always best to have a load on the PSU. It is trying to produce power, if there is no consumption of that power you can run into trouble. If there is no consumption of power the PSU can overload and die!
*STFU*PhirstAide
« Reply #3 on: March 15, 2003, 01:57:34 AM »
Quote from: outther
thanks. i never thought about it that way. still though, i'm very happy with my self for trying this and making it work.
Return_of_the_Pyro
« Reply #4 on: March 15, 2003, 03:30:56 AM »
I have blown 1 PSU from having no power going through it...
I always have an old floppy plugged into my test PSU now.
GLOOB!
Hi! I'm a signature virus. Copy me into your signature to help me spread.
Page created in 0.072 seconds with 47 queries.
