  • August 16, 2022, 04:10:08 AM
Author Topic: Review: CrazyPC Inferno Side Panel  (Read 7073 times)
jestersmod
« Reply #10 on: March 14, 2003, 09:16:26 AM »
i just got a email  from them and here is the costs
We only cut aluminum cases. We can do a custom design but the laser cutting costs are expensive. The base cost is about $150 for a design we already have. If CAD work is required it is charged at $50/hr by the laser cutter.
Regards,
CrazyPC.com
SkinnyMonk
« Reply #11 on: April 02, 2003, 12:43:57 PM »
sheesh... I think I'm stickin' to my simple dremel designs! I'd rather have 5 cases then my own "custom laser cut" case side...
« Reply #12 on: April 02, 2003, 03:08:35 PM »
usually when u post something in a thread thats a few weeks old, it says something ABOUT the product, and gives reasaon for the thread to continure.....
/me flames you :D
lightfoot
« Reply #13 on: April 03, 2003, 12:36:39 PM »
I have bought this side cover and the only problem it has is if you run a fan blowing into the case @ high rpm it has a bad wine to it. when the fan is set to exit the air its ok.
« Reply #14 on: April 03, 2003, 12:48:29 PM »
hrmm...does your fan vibrate at all?
« Reply #15 on: April 03, 2003, 01:11:03 PM »
Quote from: lightfoot
When you have it as intake, try putting/using some rubber grommets or just anything that would give a little space between the fan and the side panel.  I think the whine is coming from the fanblades spinning very closely to the sidepanel making some noise.  if you notice one side of case fans (side where air comes in), the fan blades and the center of the rotating part of the fan is almost flush to the fan's casing.
lightfoot
« Reply #16 on: April 03, 2003, 05:08:34 PM »
No it does not vibrate. It has to do with the cuts I think. I now have the fan hooked up to a control unit to slow it down a bit when I'm not playing games. when I ordered it I did not notice it had the holes for a fan. I was not planing to use one on the side of the case. but with no fan it does not look right. http://www.crazypc.com/images/cases/inferno/infernosilvercloseupfull.jpg
Pudgygiant
« Reply #17 on: April 03, 2003, 06:50:59 PM »
Holy sh*t ed, nice find.
Edge
« Reply #18 on: November 13, 2003, 09:20:38 AM »
they said it is really brittle by the center blow hole, i admit it is really thin there but it doesnt bend from what i seen, plus why would you be bending it in the first place, if your worried about breaking it off just buy a custom made fan grill from crazy pc and just put it over it. Kick ass case from what i seen so far.
brutal
    • http://www.brutal.tk
« Reply #19 on: November 13, 2003, 07:21:25 PM »
Doesn't anyone else think this side panel is ugly?  The lazer / water jet cutting is intricate but I dont understand their appeal.
Page created in 0.287 seconds with 48 queries.
