  • November 25, 2020, 11:42:39 PM
Pages: [1] 2 3   Go Down
Author Topic: making ur own eject buttons for CD ROM drives  (Read 2768 times)
[TSR]Humiliator
    • http://theshaftyrapists.4t.com
« on: March 08, 2003, 11:29:11 PM »
I want the front bezel of my case to have as many switches and knobs as the inside of an airplane cockpit.  If I could wire up my CD ROM drive buttons to 3rd party switches, it would allow for more switches on the front bezel, and would be a cool way to open stealthed drives.  I imagine that pressing the button on a CDROM drive closes a circuit, and causes the drive to open.  The main thing I need to know is how to make a toggle switch work with a momentary button.  (I would prefer an on/off switch as opposed to a button that you push and release).  Everything else I will only find out once I open the case.
  Also, if you can think of anything else that I could use switches or knobs for (besides fan speed, lights on/off, power, restart) post it here.
morphine
« Reply #1 on: March 08, 2003, 11:32:17 PM »
*drool*
Vandal Resistant Switches
*drool*
edit
"toggle switch work with a momentary button"
I don't get it.
There are momentary toggle switches. I had one in my 72 Charger for the headlight covers.
/edit
RentonLovesJunks
« Reply #2 on: March 08, 2003, 11:33:19 PM »
so let me get this straight. for the buttons, your going to use an on/off toggle. so instead of hitting the eject momentary on the drive, your going to have to flip the switch on, then back off quickly. is that correct?
if(statement==true);
just desolder the lil pushbutton switch on the drive, solder some leads to it, route them to your switch, kapowie. you have your switch.
else
please clarify.
Mr Joshida
    • http://www.tsunamicomputing.net
« Reply #3 on: March 08, 2003, 11:36:12 PM »
i've seen spring loaded momentary switches before, i'll see if i can find a link
Mr Joshida
« Reply #4 on: March 08, 2003, 11:44:01 PM »
ok, maybe i was hallucinating when i thought i saw a spring loaded toggle. but i did find this little tutorial about making a toggle switch push a momentary switch, maybe it'll help.
simsicle
« Reply #5 on: March 08, 2003, 11:51:39 PM »
I know momentary toggle switch exists. There are a couple on an old wheel alignment machine at my dad's garage that I plan to hack out eventually, since these are hard to find and often expensive.
Or you could always try http://www.google.com/search?q=momentary+toggle+switch&ie=UTF-8&oe=UTF-8&hl=en&meta=" target="_blank">Google.
Mr Joshida
« Reply #6 on: March 08, 2003, 11:51:58 PM »
YEAH, I'M NOT CRAZY  :lol: i found a momentary toggle here
    • The Site Of Doom
« Reply #7 on: March 09, 2003, 06:50:40 AM »
www.apem.com All your switch needs. Order their 500 page switch catalouge and you will know what I mean. They will even send you free samples
AMD_Junk13
    • Ross Computer Technologies
New specs tba...
[TSR]Humiliator
« Reply #9 on: March 09, 2003, 09:05:58 PM »
Quote from: morphine
I don't get it.
What I mean is that the buttons on CDROM drives are pushed for an instant and then released (momentary) while a toggle switch is flipped on and stays on until flipped off.
I'll try experimenting with an old CDROM drive.  This should be a pretty easy mod.
Pages: [1] 2 3   Go Up
Page created in 0.093 seconds with 47 queries.
