  • December 13, 2019, 04:04:16 AM
Author Topic: I want to add a window to my Gateway 700XL tower, any help?  (Read 1842 times)
*Hugs9700pro*
« on: March 02, 2003, 01:45:41 AM »
Okay heres my question. Do I need to buy this: http://www.bestbyte.net/Product.cfm?ProductID=593&CategoryID=28&Keyword=  and this:  http://www.bestbyte.net/Product.cfm?ProductID=399&CategoryID=28&Keyword=
To add the window? If I buy the latter one do I need to use some kind of knife to cut the side panel? Or does it come with it? And how do I have it stick to the side panel, thermal glue?
And heres another newbie q, are LED's easy to install?
Thanks in advance!
AMD_Junk13
    • Ross Computer Technologies
« Reply #1 on: March 02, 2003, 02:35:53 AM »
I can see that you are very new to case modding so here is a good guide on making and installing a case window.
http://www.gideontech.com/lucite01.shtml
As for the shape of the window be creative  :thumbsup:
New specs tba...
    • The Site Of Doom
« Reply #2 on: March 02, 2003, 07:26:16 AM »
You can use hot glue, some modle glues, thermal, wood (in some cases) rivits, bolts, screws, elcectrial tape, string, duct tape, tacks, staples. Just about any type of fastener will work,
Amorphus
« Reply #3 on: March 02, 2003, 12:22:25 PM »
ok, to answer your questions - the latter is a case with a window.  don't buy that.
the first one is a window kit, with everything you need to make a window except for the power tools.
you'll need a power tool for it, and I advise you don't do anything until you've read several guides on dremeling or something.
for that oval window, I recommend a dremel.  straight cuts=jigsaw, but circular = dremel and sanding drum.
LEDs are fairly easy, depending on what you do with them.
    • The Site Of Doom
« Reply #4 on: March 02, 2003, 02:05:34 PM »
I think this is the computer that the FCC would not let me buy because of some stuped EMI emmissons.... Who needs radio, tv, satalite, ecc anyway?
RaDragon
  • Tee hee hee.
    • RaDragon.com
« Reply #5 on: March 02, 2003, 05:44:50 PM »
I would not advise using a glue gun to stick your window to your case... the glue gun glue does not have a strong bond for such applications. May I suggest using "Goop" instead? It's stinkier, but it'll get the job done.
or you can always screw the window on the case...
Amorphus
« Reply #6 on: March 02, 2003, 08:41:14 PM »
he's thinking of one of those window kits that come with moulding...
Page created in 0.071 seconds with 19 queries.
