  • November 22, 2019, 04:08:45 PM
Author Topic: 'Mini HSF'  (Read 2196 times)
Return_of_the_Pyro
'Mini HSF'
« on: January 24, 2003, 01:24:36 PM »
would you guys trust this?
GLOOB!
Hi! I'm a signature virus. Copy me into your signature to help me spread.
'Mini HSF'
« Reply #1 on: January 24, 2003, 01:28:42 PM »
what are you trying to cool?  Anythign greater than a small celeron chip like a celeron 600 (11.6 watts of heat), I would have to go with a big NO!
RentonLovesJunks
'Mini HSF'
« Reply #2 on: January 24, 2003, 01:34:21 PM »
ohhh that just has FRY written all over it
i wouldnt even put that on a cellery. the one i had was 40x40x40.
Return_of_the_Pyro
'Mini HSF'
« Reply #3 on: January 24, 2003, 01:36:03 PM »
well... I may get one for my P200 MHz soon to be OC'd... I was thinking 'WTF! LOOK AT MY FAN NOW ON MY PROC!?!'
GLOOB!
'Mini HSF'
« Reply #4 on: January 24, 2003, 01:42:55 PM »
would be a good chipset cooler though
Fanny J. Crosby
'Mini HSF'
« Reply #5 on: January 24, 2003, 01:47:31 PM »
Yeah, probably a good chipset cooler if your chipset has that much room around it.
All Your Base
'Mini HSF'
« Reply #6 on: January 24, 2003, 09:55:53 PM »
Wouldn't touch it W/ a 6 foot pole!!!! And for a chipset, just file it down, and mount thr fan above anything else it dould hit, add duct tape to channel the air. Otherwise, stay away from it!!!
redfox
'Mini HSF'
« Reply #7 on: January 24, 2003, 10:10:32 PM »
dang! my video card cooler is bigger than that!
and its only an mx420!!
wussap!
Gremlin484
    • http://www.elitepcrepair.com
'Mini HSF'
« Reply #8 on: January 26, 2003, 02:46:04 AM »
unless you only wanna run the comp for about 2 seconds before it overheats and dies, i'd suggest NO.
mp3.com/wvsoulja
    • http://www.mp3.com/wvsoulja
'Mini HSF'
« Reply #9 on: January 26, 2003, 03:05:42 AM »
Are chipset coolers worth getting? Will they provide a preformance increase? I have 3 diodes on my system, says motherboard monitor 5. Sensor 1 is CPU, 2 I dunno, and 3 I dunno. 2 I'm guessing is case temp, cause it's 30C, sound right?
Page created in 0.042 seconds with 18 queries.
