  • February 25, 2020, 03:31:34 AM
Author Topic: burning cd ,first track not reading!!!!!!!!!  (Read 2968 times)
Anonymous
« on: August 09, 2001, 12:41:00 PM »
i do abit of burning but found the first track on cd is not read in cd player,found last night its reading -99:59 mins b 4 track 1 any ideas on y? and how to fix it;  using nero 5.5 & musicmatch maker 6 software,it also did same with easy cd. for god's sake someone help me!!!!!!!!!!!!!!!!!
f1int7
« Reply #1 on: August 09, 2001, 07:30:00 PM »
maybe you wanna post this in another forum..hehe. Like technical support or one of the software forums.
brutal
    • http://www.brutal.tk
« Reply #2 on: August 10, 2001, 04:08:00 PM »
hmmm i use ezcd 5 plat, cdrwin, clonecd and fireburner for burning cds and they all do things slightly differantly but they all will burn the same way so im thinking you are possibly leaving the session open, writing track by track (most likely) or something is wrong with your burner like its miss aligned but that doesnt happen often so try writing with ezcd in disk at once mode with it closing the session when done. if that isnt working borrow a burner from a friend and try to eliminate possible causes
Vinny_Knoxville
    • http://Coming Soon
« Reply #3 on: August 11, 2001, 12:21:00 AM »
Some Audio CD Players do have trouble reading CD-R's but if it's read it before I suggest try burning another CD and if that doesn't work, then sharpen the edges of the CD's into razor blades and throw them at passerby's in a fit of rage
devilside
    • http://www.crazymod.2ya.com
« Reply #4 on: August 17, 2001, 02:58:00 PM »
or just get an new burner :)
mneome
« Reply #5 on: August 30, 2001, 11:26:00 PM »
the other option is of couse to just buy the damned cd in the first place, just a thought
Page created in 0.07 seconds with 33 queries.
