  • June 06, 2020, 09:51:38 PM
Author Topic: 1/2 or 3/8  (Read 1746 times)
TxTiger04
1/2 or 3/8
« on: January 21, 2003, 04:49:00 PM »
what are some pros and cons of each size tubbing for watercooling??
1/2 or 3/8
« Reply #1 on: January 21, 2003, 05:55:42 PM »
bigger means more water running through it.
Return_of_the_Pyro
1/2 or 3/8
« Reply #2 on: January 22, 2003, 04:18:05 AM »
so why would you use smaller?
GLOOB!
Hi! I'm a signature virus. Copy me into your signature to help me spread.
Daneel
  • Briefcase PC
    • Clan | 43
1/2 or 3/8
« Reply #3 on: January 22, 2003, 06:55:57 AM »
faster waterflow
Gremlin484
    • http://www.elitepcrepair.com
1/2 or 3/8
« Reply #4 on: January 22, 2003, 12:29:50 PM »
If your resivour is rather small, i'd use 3/8... if it's bigger, go with 1/2... the more water you have within the system, the more you have to dissapate the heat with. Also, make sure your pump can handle 1/2. anything with about 250 GPH or better should work fine. I use 1/2 and it works wonderfully.
TxTiger04
1/2 or 3/8
« Reply #5 on: January 22, 2003, 11:39:48 PM »
thanks guys...think ill go with 1/2
RentonLovesJunks
1/2 or 3/8
« Reply #6 on: January 22, 2003, 11:47:45 PM »
i read an article somewhere. basicly said that if you already have a 3/8 system, the performance increase isnt worth an upgrade. but if your building a new one, go with the . so there you go. have fun and good luck.
Page created in 0.069 seconds with 34 queries.
